Blizzardx23's Pick-n-Pull thread
BlizzardX23
BlizzardX23
Sacramento, California
Heres stuff from the yard....
This is from ONE Denali
These are from a DIFFERENT Denali
Avalanche Midgate
A couple Tahoes
ecordell
CordellDesigns.com
Merica
Could you check on a cluster from a denali? See how much one would cost.
dropmech
Puddle Pirate
Coral Springs
Bliz, yes I can put the brackets in. All Tahoes came predrilled. My holes are filled in with plugs I have to remove. Also, how much for that grille? Are any of the grills Silver Birch?
andrewmoore13
can you look for an '03+ dash bezel and radio cage? preferably for a denali with the dark wood grain trim.
possibly an escalade cluster/lens (lens is preferred)
ghost
Senior Member
ill take you up on that all white grill shell if know one is interested allready!
---------- Post added at 03:28 PM ---------- Previous post was at 03:25 PM ----------
also on the center console i cant find a good pic.. but one like the one in your boy Kaseys hoe!
AquinoSteven
Key and Spacer Guru
Clinton, NJ
If its not too much trouble.
2000-2006 LT fogs with the male/female plugs or
2000-2006 Z71 lower valance with fogs and plugs.
I prefer the Z71 but ill the the LT fogs if it too much trouble.
THANKS A TON!!!!!!
thehoe92
fo sho
The916
Blizz!!! next time you go take me I got a whole list of things I need to get
particularly a hub assembly so I can get an alignment!
CaliCrusin
