Brake pedal fluttering
nofaz
Bismarck
With new pads and new rotors after the first brake job I would have thought that everything would be nice and smooth. The problem started right away though and continued when I put in the new rotors the second time. If I had the ability I think that bleeding the brakes would be the next step.
wjburken
Eastern Iowa
Bleeding your brakes is pretty straight forward. Helps to have someone help.
Just start at the rear passenger wheel, crack open the bleeder cap on your caliper and have your helper pump the brakes, being careful not to go all the way to the floor, until you have no air bubbles or, if you are replacing the fluid, you have clean fluid. Make sure you keep the reservoir from going empty. Once that wheel is done do rear driver then the front passenger then front driver.
