Brake warning lights coming on
withac
withac
Eastern Idaho
don't know, I don't get the ding. What I would like to know if someone can answer this, will it damage anything to just ignore it? If it is an itermitent problem I'm guessing when the lights are off I have my ABS functional, when the lights come on I might not have ABS. That being the case, if I pull the fuse I'll never have ABS, if I leave it alone I'll have them when the lights are out. OR will it damage something if I let it go?
nmsyukon
The mechanic next door to us told me that in some cases the ebcm will cause the abs pump to run all the time. Basically, this would be the only scenario that something else would be harmed. Also, my abs is still functional when my lights and warning come on.
withac
withac
Eastern Idaho
I guess that's what I was wondering, if the pump runs all the time is it going to burn something out. Doesn't sound like it would be too good for things
nmsyukon
Yes, it is my understanding that the battery would die and the pump would eventually burn out
withac
withac
Eastern Idaho
If it shuts down when you turn the truck off it shouldn't kill the battery, right, but you'd still run the risk of toasting the pump if you drove very far with it running constantly, right?
nmsyukon
Correct, but they said that sometimes it might keep running even with the vehicle is shut off.
Rossimon13
CT
I am having all these same problems, ABS light, Stability Control light, and tpms light. I replaced both front hub assemblies and that did not fix it.
Fast forward to yesterday, going about 80 on the highway, both rear brakes LOCKED UP for about 2 to 3 seconds. I have been driving this thing with the lights for a few weeks, but now I am ready to get this fixed!
A lot of great info in this thread, if anyone has any advice let me know. Thanks
---------- Post added at 12:10 PM ---------- Previous post was at 10:57 AM ----------
I will add that all this happened after I brought my car in for alignment, tire rotation and oil change at bridgestone. The service tire monitor was already on, but after the visit abs and stabilty came on. I don't think they did anything wrong, and I know the service manager very well, but it is a little coincidental.
Trying to learn my tpms does not work either, passenger rear wont connect.
Also I cleaned up the ground connections, didn't help.
Rossimon13
CT
Well mine ended up being a simple fix, drivers rear abs wire or speed sensor (whatever it is) was frayed, spliced it back together and shes good to go...
Capeles
