Brake warning lights coming on
A623Z
Phoenix, AZ
I had the same issue awhile back too, It's the speed sensor. The speed sensor is sealed inside of the front hub so I just replaced my hubs and haven't had any issues since. There was a recall on the front hubs for 00-06 I believe
Splatmaster527
Cleveland, OH
I think you guys need to slow down on the EBCM assumptions and maybe check some of the smaller things first like some of the last posts.
Check wires and connections on sensors before going crazy on repairs.
My lights were going off and my brakes were really loose and I couldnt stop very well... I replaced my front hubs and not only did all the lights go off and the brakes work perfectly but my ride is much smoother and quieter up front!! I guess 190,000 mile hubs start to suck pretty bad!!
withac
withac
Eastern Idaho
I've had zero problems with the brakes or performance, it's just the park brake light and ABS light stay on. Would there be a code set for a speed sensor? Where do you find out of there was a recall?
A623Z
Phoenix, AZ
autorecalls.us
This is what I found on mine
1. NHTSA Campaign ID Number: 07E106000
Recall Date:
2007-12-17
Summary:
CERTAIN FEDERAL-MOGUL REPLACEMENT WHEEL HUB ASSEMBLIES WITH THE BRAND NAMES: NATIONAL, CARQUEST P/NOS. 515020, 515021, 515025, 515053, 515054, 515059, AND 515060, SHIPPED BETWEEN JANUARY 23, 2006, AND DECEMBER 20, 2007, SOLD FOR LIGHT DUTY AND MEDIUM DUTY TRUCKS. THE INBOARD RETENTION NUT USED TO MAINTAIN HUB BEARING ASSEMBLY CAN LOOSEN RESULTING IN AN ABS LIGHT INDICATION, NOISE, AND/OR WHEEL SEPARATION.
Consequences:
WHEEL SEPARATION CAN RESULT IN A VEHICLE CRASH.
Remedy:
FEDERAL-MOGUL WILL NOTIFY CUSTOMERS AND WILL REPLACE THE HUB ASSEMBLY FREE OF CHARGE. THE RECALL BEGAN ON FEBRUARY 7, 2008. OWNERS CAN CONTACT FEDERAL-MOGUL TOLL-FREE AT 877-489-6659.
Component Affected:
WHEELS:CAP/COVER/HUB
Potential Cars Affected:
130,000
Notes:
FEDERAL-MOGUL CORPORATION
withac
withac
Eastern Idaho
autorecalls.us
Recall Date:
2007-12-17
Summary:
Consequences:
Remedy:
Component Affected:
130,000
Notes:
Thanks. If I follow it correctly, the wheel hub assemly one only applies if the hubs have already been replaced, not if they are stock, correct?
ajaxnxs
Rockwall,TX
autorecalls.us
Recall Date:
2007-12-17
Summary:
Consequences:
Remedy:
Component Affected:
130,000
Notes:
Thanks for this site. I hope that this will solve some of my issues with my Kon.:Handshake:
chip
Tampa
I had my ABS codes pulled today. Anybody familiar with "CO265 - EVCM Motor Relay"??
01Tahoe
Here
Any updates with this? My tahoe is giving me the same problem with the ABS and brake warning light.
acribb09
