Brett's 2004 Escalade 6.0 AWD build
95escahoe
95escahoe
Okay, that makes sense now.
I've started noticing some people with white turn signals. They flash white. Some rear, some front. I thought to myself "no way that's legal"
Same here see that a lot on the ricers honestly I can’t see doing it on the rear tho that’s just asking for an accident
adventurenali92
Big Bear Lake, ca
The 3157 turns are flashbacks when they are on they are amber but when they are off they are pure white to match the DRL and side marker bulbs, no inspections here, I had this HU sitting around for 3 months lol I got sick of only having one button light up on the factory HU
That’s pretty rad! I think I wanna do that to mine to math my white DRL bulbs. What brand are those bulbs you got?! And did you have to wire in anything behind the bulb to make it work properly?!
95escahoe
95escahoe
These are the bulbs I used for the 3157 https://hidkitpros.com/shop/3157ck-dual-color-led-bulb-60-smd/ these are the 194’s https://hidkitpros.com/shop/hkp-t10-194-led-bulb-diffusion-lens/ I get all my LED’s from them they are top notch & high quality, and no wiring just plug and play to get them to flash correctly I added an LED flasher but that’s easy to swap out
adventurenali92
Big Bear Lake, ca
What’s an LED flasher?
Edit: I’m assuming the 3157 is the larger turn signal bulb right? Like on my truck that would be the larger turn in between the DRL and the small corner? And the 194 is the small corner turn signal?
HiHoeSilver
Away!
Chicago
Flash module to eliminate hyperflash. Yes on sizing.
95escahoe
95escahoe
Finished up the CD changer delete today
You need to bend this tab back slightly to fully seat the pocket, it fits nice and snug and once the console is back in front there will be zero movement
This is the pocket I used it’s Metra 98-8999
95escahoe
95escahoe
Came across these 22” Escalade rims today, they look to be in pretty good shape, has the Escalade center caps, plenty of tread left, once I sell my rims I’ll probably be into these for $400, what’s anyone think? I know I was going for that murdered out look but I think these would look great too
adventurenali92
Big Bear Lake, ca
I like these wheels a lot! Very classy looking wheel and I think they’ll fit wonderfully on your caddy!
95escahoe
95escahoe
I think they would to, I’m just debating do I leave the chrome on the rack and boards or do I wrap that and just throw these on
adventurenali92
Big Bear Lake, ca
Leave the chrome in the rack and in the wheel inserts. It’ll tie in together plus I the racks look a lot better with the chrome as is. I’ve seen it wrapped and painted to color matched, and it looks good, but I also really like it chrome because it just looks right chrome.
Lorenzo33
