Broken Motor Mounts
CobraKing
I just got my poly mounts and am eager to install but worried about the vibration.
The drivers side oem mount is the mount I destroy every year or so and have to replace. I'm wondering if I should just install the poly mount on the drivers side and either stay with oem or h2 for the passenger side. Any opinions would be appreciated.
Sent from my SM-G950U using Tapatalk
Generally not a good idea to mix and match engine mounts. The polyurethane mount on one side will be too rigid and the engines vibrations will be channeled to the weaker durometer mount. In general the car might 'feel' like shit due to the imbalance.
I've got a Tahoe PPV which comes standard with the H3 mounts and others have them already so why not go with them?
08grey
My weak point on the oem mount it the cross bolt that holds the two ends together. Every time I change it this bolt is bent.
Mrsteef
One thing I noticed with the h3 mounts is better gas mileage (now with new h3 mounts vs broken factory mounts). I’m not sure I would want to go with poly mounts after getting used to the slight vibrations I feel with the h3’s. If it were me I’d either go full poly or full h3. Half and half to me is kinda pointless. Quick side note also it’s alot easier to change them from underneath the truck (2wd) if possible. Passenger side just remove the starter and it’ll pretty much fall out.
randeez
south florida
Btw...lol
They seemed to lower the engine quite a bit...went from headers tight on top to rubbing on bottom after putting them on.20181007_164635.jpg 20181007_164636.jpg 20181007_164731.jpg
tgui
Strange. I saw no height difference. It's hard to guage when stock mounts can be so ******.
Still, great install. I was amazed when I could floor it and nothing rubbed or moved
Post vids!!
tgui
I just drove my Denali with the h3 mounts. No more vibration than with bad oem mounts.
eb5665
