Broken Motor Mounts
Anybody find them for less than $80 each? Seems to be the going rate.
The cheapest I found and where I got mine was from Rock Auto at $76.79 each. I have an Amazon Prime account and, even though shipping would've been free, RA's total price with shipping beat Amazon's price. Also, Amazon would've had to drop ship them from the supplier and they wouldn't have been available until sometime this month. On top of that, RA has a 5%-off discount code. I got two H3 mounts and an OEM transmission mount (currently $17.89) delivered in 3 days for about $176.
Installed them last night and couldn't be happier.
tgui
What shape was your trans mount in?
I think it could've stayed. It wasn't torn, but the rubber was obviously aged and had some cracks in it. Compared to the new one, it was almost an inch shorter. Either the new one will settle a lot or the old one had squashed that much over time. For the additional $20 and 20 minutes of labor, I'd rather have ALL the powertrain mounts be fresh so everything is in or closer to it's originally designed location. Considering I'll be lowering it, having the tailshaft at it's intended height and angle can help with driveshaft, U-joint and pinion angles which will be more important when lowered.
George Hoffman
Well mine is a 2000 Z71, old body style. Both of my motor mounts are shot after a day of mudding. My mechanic says he has to drop the front differential and then lift the body, then lift the engine. Don't know where you priced the motor mounts but mine were only like 16 bucks a piece...
tgui
Uhhh, your mechanic is over selling what needs to be done. I did mine with diff in, engine slightly jacked up, manifolds removed on my back in my garage.
Hell, I bet I could do it with manifolds in but taking the starter out for the passenger side.
Edit, obs? Whoops missed that
Doesn't matter if they were 5 cents a piece- they're nothing like GenIII/GenIV mounts.
LMAO you new guys kill me. Do you realize where you are, in the 07-14 NBS area? Different animal.
sneasle
North AL
Can you folks help me out a bit? I'm working my way backward through this thread, and it looks like 25847739 is the PN for the H3 engine mounts. Are their other mounts that I should swap (tranny, etc) at the same time? If so, are their H3 version that work there as well, or should I go with original?
The H3 mounts are for the engine only. There’s nothing wrong with the design of the original trans mounts and they rarely if ever fail however if you like there’s nothing wrong with replacing it too.
That is the correct part number. It's the RH (passenger) side mount for an H3. You'll need two of them as that mount will fit both sides of our trucks. The trans tailshaft mount is the only other powertrain mount. As Mark said, it rarely fails but it certainly won't hurt to replace it. I wanted all my mounting points to be fresh and the trans mount was only $20 and took about 20 minutes to change. My original one had cracks in it but wasn't separating. There's really no lateral movement in that area to separate it, it really should just squash over time as it ages and settles. I'm sure all the extra movement from my blown engine mounts torqued on the trans mount to cause the rubber to split.
Safetypup
