Broken Motor Mounts
Rwayne
Arlington,TX
The starter is on that side, unhooking the battery is a good idea. I was able to get that side out without removing anything on that side. I rolled it towards the passenger firewall and then up. I did have the intake and plastic from up top removed and the driverside mount loose.
Thanks
Anyone know the trans mount partnumber?
If you're replacing both sides, don't bolt down one side before doing the other so you can leave the engine jacked up for more work space. I didn't remove the starter. I did have to disassemble the old mount and remove it in two pieces. The new mount went in after some creative twisting and turning, working through the fender well.
ACDelco transmission mount part numbers are:
4WD: 15840277
2WD: 15813693
Kenny D
Crosby, Tx
Can someone point me to the right page where this H3 part number is located, my driver side gave out again.
Kenny D
Crosby, Tx
Yea I totally forgot about the 5% and I just ordered a complete front end and the motor mount. $590
LAKETAHOEBLUE
