Broken Throttle Body Post
LeeAb
I'm hoping this is easily replaceable without taking apart the intake manifold.
Can anyone help me with a replacement part number?
And - is it as simple as screwing the broken post out and replacing with the new one.
Thanks in advance!!
sk1dm4rk
I'm not 100% sure, but I believe that is exactly how that works. If you look at the one that is still intact, it has a hex on the end? So, try grabbing the broken stub with vise grips and see if it turns. Don't wrench ******* it, you don't want to break any plastic bits if this is not the correct way to do it.
Good luck.
L
LeeAb
Good luck.
Thanks! It looks like vise grips will work for removing the broken stud.
My biggest problem now is finding a replacement.
I'm hoping someone knows or can look up the part number.
L
LeeAb
After researching online and making some calls, I was told that GM 89017591 is the item I'll need.
Order is placed and I should have it in a week.
Now I'm just hoping they're correct.
sk1dm4rk
You're welcome. Be sure you update this thread with the results once you get it fixed to help peeps in the future.
khg30
