California Smog and IM monitors
99 2dr
99 2dr
The Real Nor Cal !
I pulled the valve out and verified that it is closed. I re installed the valve and started the engine with the hose that connects to the manifold check valves disconnected. Plenty of air flowed through the valve when the pump came on. I checked the hose that goes to the manifolds. There was a very small amount of air coming out of it from the exhaust. Should I change the two valves? What is my next step?
There is a beer waiting for you in Redding California if you ever make it up this way!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
In that case you you need to get a scanner then can see live data and monitor the o2's from cold start. When the pump is on they should show a lean mixture even tho the the engine pcm is actually running the injectors rich because of a cold engine. When the pump goes off you should be in closed loop at the same time and the sensors should be midrange in voltage. If not it is possible that the the sensors might be lagging a bit.
99 2dr
99 2dr
The Real Nor Cal !
If that were the case, then new oxygen sensors would be in order? What kind of voltage numbers should I be looking for?
ccapehartusarmyINF.(ret)
Gilbert AZ
holy crap california legislature have far to much time on there hands they just like to pass poimtless legislation every day lilke more emissions crap or banning plasti dip in gallons
99 2dr
99 2dr
The Real Nor Cal !
It would be unwise to post on the internet the things that the people in rural towns would do to the people at CARB.
Ok, so this morning I fired it up dead cold.
The 02 sensor readings while the Air pump was running this morning were:
Bank one s1 .45 S2 .29
Bank Two s1 .19 S2 .36
Its pretty hard to get an accurate reading while the numbers are bouncing around. these are the estimated average reading.
SunlitComet
OBS Jedi-Do Good
Theoretically if those average were indeed true of accurate sensors then B1S1 would seem to not be getting enough air from the pump. B2S1 seems about right. Reading also indicate that the converters are doing a good job o their own as well. If you were to swap B1 and B2's S1 and the "mid reading" followed it then the sensor may be goofed. Try something easy and check on the flows of the air pump as felt from the manifold check valves to see if they are even. Or did you already do that?
---------- Post added at 01:31 PM ---------- Previous post was at 01:27 PM ----------
BTW, Have you checked the readiness monitors again lately to see if more locked in? Since the other was egr remove it and clean it out carefully and the same with th TB by spraying with a lot of cleaner and make sure the small hole in it is not plugged.
99 2dr
99 2dr
The Real Nor Cal !
I checked the flow at the valve. I will check the flow at the check valves on the headers.
I re checked it and the voltage is much higher at bank 1 sensor 1 than bank 2 sensor 1. I happen to have a new set of 02 sensors that were waiting to be installed. I might stick a new one in bank 1 sensor 1 and see if I get lower readings.
All of my readiness monitors are good except the EGR and AIR still.
99 2dr
99 2dr
The Real Nor Cal !
I Installed the new oxygen sensor in bank 1 position 1. The voltage readings Now match bank 2 sensor 1. I pulled the EGR valve, and replaced it with a new one. I had a buddy stop by with a snap on scan tool. First we preformed the drive cycle test. No luck, the air and EGR still were incomplete. We hooked up the snap on scanner. The scanner says that the Air test passed, but was still incomplete. The EGR still failed. So we manually activated the EGR valve with the scanner and it worked. From there, we drove with the scanner hooked up to live data stream. At no point under any circumstances did the EGR valve function while driving.
So where do we go from here? Could this be an issue with the BB tune? The Edelbrock TES headers, and the BB tune are my only engine and emission mods.
SunlitComet
OBS Jedi-Do Good
egr hardly does work while driving. Mostly stays closed unless it is required to lower combustion temps based on data from pintle's position, TPs, ECT and MAP sensor. Does not take much for that valve to lean out and engine with the throttle closed so don't be leaving open other then for the quick test. While observing the map command the egr open to 30% percent engine running. If you see the MAP go higher and the egr will follow commanded movement with engine running and not then the egr system is fine. If the headers ar CARB E.O. then don't worry about it consult with BB about the adjustments to you pcm tables that might be affecting it. Did not know you were tuned. They may have disabled it possibly.
