Catalytic Converter...
OR VietVet
Multnomah Falls
Military
Willamette Valley
Without detailed diagnostics the cats and pipe replacement is a best guess. The bank 2 downstream sensor has been changed already in December, for some reason, and since the likelihood is that the bank 2 downstream sensor is working ok then the source of the problem is again the cat. The cats come as a one piece unit with the y-pipe so it only makes sense to change the bank 1 downstream sensor during this process, to have 2 downstream sensors of relatively the same age. One of the things I should have asked is what brand of sensor was replaced in December?
The P0430 code is all about cat efficiency on bank 2 and that is related to the downstream sensors or the cats themselves. If he is doing all this work I recommended the downstream sensor on the bank 1 side. I also said, again if he can afford it, to do the front sensors as well with all sensors being good quality parts. Such as these:
https://www.rockauto.com/en/moreinfo.php?pk=438154&cc=1412244&jsn=2239
In this case the upstream and downstream sensors are the same.
rockola1971
Indiana (formerly IL)
Depending on how plugged the cat is you can hit its inlet with a thermal gun and then hit the outlet too and see what the temp difference is. If there is a substantial temp difference then the cat is plugged. I wouldnt expect to see much more than 10-15deg temp difference. Thermal (Infrared thermometer) can be had cheap on Ebay, Harbor Freight, etc.
A plugged cat will be hot on inlet and substantially cooler at its outlet.
Jon Abbondanza
Just when I think I'm at the end, something else happens. I started getting the P0430 error about a week ago. Engine seems to be running like a champ after I fix the oil pressure sensor. The engine doesn't sound funny or have any loss of power. I've changed out the downstream O2 sensor on bank 2 back in December. From what I'm reading, I should change out the upstream sensor before switching out the catalytic converter. I guess I can do that, but I feel like it's going to be a waste of time.
Any high recommendations from one off RockAuto or Summit? I've seen some pretty cheap ones on Amazon, but I'd rather just get it done the right way. Looking for recommendations on what I should buy. Also, should I go ahead and change out the muffler while I'm at?
Yes such is life with trucks at or approaching the 20 year mark. Better than a car payment, I say!
This is what I bought when my cats failed (not sure what 'do it right' means): https://www.amazon.com/gp/product/B01NARS9TR/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
easy install, decent price, did the job
mijohnst
mijohnst
I'm in the process of getting the old one off now. I've spent the last 3 days just hitting those nuts on the exhaust manifold with the recommended penetrating oil that Ron suggested. Today I'm working on getting them off. Holy crap they won't budge! They don't look all that rusted either. I really thought that they'd come right out because in several of the YouTubes I've seen the bolts are in way worse shape than mine.
It also doesn't feel right because a 15mm feels just a little too big because I do have some play. A 14mm is too small and a 5/8 is too big so it must be right. It just feels like it's going to round over that nut if I push any harder. So an impact wrench is probably a bad idea, right? lol
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
mijohnst
mijohnst
An impact is a bad idea. Heat is my go to with these jobs. I have an oxy/acetylene torch and using a small brazing tip have almost 99% success. Before I had that torch I used this little guy. Just had to have plenty of oxygen tanks.
https://www.homedepot.com/p/Bernzomatic-WK5500-Brazing-Torch-Kit-361487/300055608
George, earlier I had read about heating that nut up with a propane torch so I bought one at Lowes a few hours ago. I got up there and heated one nut up until it was slightly glowing red and tried again and it will not move. I've been trying to be very careful but I can feel the corners of that nut rounding over. I've tried every 15mm socket I have and they're all the same. They all just feel slightly too large because of the play. It was like that before I even started but worse now. I'm thinking I might need to use a nut splitter to get it off now...uggg. Thanks for the reply!
ks03
Fool Excess Member
get it glowing bright, as hot as your torch can get it, or stop when you see it deform, melt or bubble, and hit it with the impact. run a rethreader on the studs, and get new nuts to go back on
It is originally a 15. if it’s wilted down from rust enough, I’ve used a 9/16 on a rare few.
mijohnst
mijohnst
Well, nut splitter it is. I just went out to try again. This time I got the nut glowing red... I put the socket on and it spun completely around and bolded it. Damn it...
mijohnst
mijohnst
Thank you M. I got it as red as I could. Those nuts weren't that rusty either so I don't know why a 15mm didn't fight tight on them. Maybe my Craftsmen sockets are larger than normal or something.
Manekwa
