Catch can flow discussion
Top one is the oil after 5k miles from the cheap cc on our 191k mile 07 Yukon.
Bottom is the oil after 5k miles from the pricie cc on our 68k mile 02 Corvette.
The problem with this comparison is the Gen 3 engine tends to not blow as much oil as the Gen 4. Unless you drive your 'Vette very differently than your Yukon! It'd be awesome to swap the cans between the vehicles and drive them just as you normally do and make another comparison at the next 5K mile interval.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
So far, it seems the consensus is to have the inlet hit the filter. That's what the "big brands", which I'd be inclined to believe have put more R&D into their products than the Chi-clones, seem to agree on. But that's not to say that having it reversed won't work, either.
I'm gonna stick to my assessment that make a whole lot of difference, assuming you have proper coalescing media. But, where it would matter is if you're trying to keep something in the engine (like oil) and just catch what makes it through versus trying to vacate and capture something (like moisture). If just oil, inlet goes directly to filter. If moisture, inlet goes to reservoir.
I capture oil in the summer and lots of moisture in the winter with mine.
k_arnold72
I have a JLT as well and get about an ounce every oil change. I've used Blackstone in the past, if I'm not mistaken, I believe the instructions ask you to take the oil sample from the crank case. The results will tell you what trace amounts of metals are found in your sample, where that metal comes from and how it compares to similar engines.
*Sucks teeth*
See, now you just tryna be difficult!
You should get two: Valve cover in to unfiltered port of first can, out of filtered port of first can in to filtered port of second can, out of unfiltered port of second can in to intake manifold. Cover all bases and transcend us single can peasants.
George B
¯\_(ツ)_/¯
*Sucks teeth*
No Sir! I ain’t foolin wit it no mo.
89Suburban
Bull in the china shop
SE PA
Wouldn't it work better then? If the oil has been stalled and scrubbed from the air, and has coalesced on/in the filter media (the bronze plus the added scouring pad), the droplets would already be too big to remain "in flight" to get to the "unprotected" outlet port. Going the other way, the oil is already stuck to the filter media and is being pulled through via engine vacuum at all times. Eventually, it'll get through and make its way up the hose to the intake manifold.
The oil would have to pretty much be solidified in the hose to be a restriction. Obviously, it's very far from being a solid. Also, a restriction stalls air flow and this weakens the vacuum on a fluid substance. If there's enough oil going through the PCV system (through that tiny hole in the PCV "valve", for one), to fill the 5/16" hose, then your engine was already moving that much oil and it needs more help than a catch can would ever provide. Does an oil-soaked brass filter reduce air flow? Of course. But it's not enough to cause excess pressure inside the engine or affect engine vacuum in any amount the PCM sees and reacts to.
j91z28d1
select the 400$ dual one for ls engines and hit buy now lol
hb3dClean
