Cel after oil sending unit replacement
PaDenali
Hi,
11 denali 6.2
Had oil sending unit replaced, they Took off manifold to do it, now i have random misfire code that I didn’t have before this, any guess as to what is wrong now? If I continue to drive it, what damage could it cause?
take it back and request they replace the gasket on the intake they took off, they probably didn't use a new one and just stuck it back on, now it's leaking (sucking air in)
P
PaDenali
ok, that was my guess also, tach moves at little at idle, but don’t notice other driving issues, I think i hear a vaccum sound, but not sure
unless the leak was really bad you probably could not hear it, you can test for a leak by spraying starting fluid around the edges of the intake where it mounts to the engine and see if the idle goes up, when it hits a leaky spot and gets sucked in the idle will change abruptly.
P
PaDenali
Ok, so they say no leak, replaced plugs and wires, and after 20 miles light came back on.... they were original plugs
CobraKing
Can you try a different shop? Feels like they are throwing parts at your truck and charging you for it without doing any kind of analysis.
@Doubeleive provided a useful diagnosis suggestion.
mechanic0
