thompsoj22
- Joined
- Jul 21, 2018
- Posts
- 689
- Reaction score
- 717
Replaced the current sensor module on the naegative battery cabel and completely changed how the alt was reacting to load demand. I removed the 2.6" installed a 2" overdrive pulley on the alt and with every accessory running in the desert heat the volts do not drop below 13.2. On the highway the RVC system functions as designed and rolls the volts back when not required. the current sensor was definitley degraded but the overdrive pulley is the ticket for idling amps!. Amax alt RPM of 18K will only be exceded in the 5K RPM range and i rarely if ever plan on pushing that hard.
