Check Engine Light After LED Interior Light Install
BoutDrama
Geoffsfas10
St. Louis
Did you see what the check engine light is for???? it might be completely unrelated, just a weird coincidence. These trucks dont have a CANBUS system so I would think its something else.
I changed out all of my interior and exterior lights with LEDs, and I did not trigger any warnings on the dashboard. My initial thought is that your issue may be unrelated to your LED conversion. Do you have a code reader, so that you can see what code is being thrown to light up the check engine warning?
BoutDrama
BoutDrama
No code reader, BUT, the wife said she took a ride in it, and the light was off.
BoutDrama
BoutDrama
Apparently, the light is now off so I guess the issue was resolved? I don't have a code reader, but I will be buying one soon as I can.
the code should still be there as a "history code", so whatever it was it failed, then passed so the light went out, you might want to get it scanned to see what it is, then you can prepare to fix whatever is going out, usually cheaper to do it that way anyway because you can order the part online cheaper instead of having to pay retail. Most of the time a check engine light is smog related and not usually something critical unless it flashes at you which indicates a misfire and potential engine damage if ignored.
changing your interior lights to led would not trigger a check engine light.
BoutDrama
BoutDrama
Gotcha, I'll follow up
swt_wxw
