skpyle
- Joined
- May 15, 2021
- Posts
- 420
- Reaction score
- 1,106
Will do. Thank you!change the oring on the MAF sensor it has a leak
looks like it has caked on dirt so it must be leakingWill do. Thank you!
I always thought of Johan and the Chief when speeding out the inlet or in my drag car.Very true. I am always in a heightened sense of awareness the faster I go. Because I know it will go wrong quickly. I am always listening/feeling the feedback from the vehicle...
where did you get your Tech 2 and Candi?I reinstalled the cleaned throttle body with a new gasket. It probably did not need it, but the service manual said to replace it. So I did.
(Note: I am still new to 'late model' GM, so I don't have the experience with them to tell me what can and cannot be gotten away with.)
Installation was simple and straightforward. However, in a bit of OCD paranoia, I installed the nuts and bolts and tightened them with my fingers. Then, with a nut driver, ran them all down by hand in stages. Then I torqued them to 89 inch/pounds. Point of all this was to evenly compress the throttle body gasket in its groove in the intake manifold.
New ACDelco 125889235 throttle body gasket at left, old gasket at right.
Cleaned throttle body back where it belongs.
Next step was the Throttle Idle Relearn procedure.
Tech 2 and Candi module in use.
Tech 2 screen for Throttle Idle Relearn. Note Reset soft key.
And..it worked!!!
I started the engine cold, it hit high idle of 1200RPM, as commanded. It then dropped down near commanded idle of 664.
Success!
However, I did not drive it. I will drive it to work tonight. I don't fore see any issues.
chinacardiags.comwhere did you get your Tech 2 and Candi?
