Cleaning throttle body
TheAutumnWind
I put my serpentine belt (used to be called a Fan Belt) on wrong and it wore a hole in my air intake plastic body which caused acceleration from the petal impossible and the digital warning "reduced engine power."
If you have an air leak between the air filter and the air intake this will happen to you. Check for Leaks/cracks loose connections go towards the air intake and you may have found the problem.
it was a fan belt when it turned a fan. Now fans are electronic and it turns all other accessories....
Bfriskney8
