@Doubeleive how you like that Cold Case radiator? I'm discouraged I didn't know about them when I ordered my new one. I would have totally sprung for all metal, larger radiator!
@rockola1971 where are you in the Midwest?
Seems I should make a external voltage regulator circuit so they can rebuild the newer alternators
My background is embedded systems engineering. Last major project was a Lithium Polymer battery controller for an aircraft. Had to write control stuff for charging once APUs got started as well as for starting up the system. I think only difference on newer alternators is the voltage regulator is in the PCM?
Currently fiddling around building some other stuff after work / Bluetooth devices.
