Matthew Jeschke
Dang it. Was doing so well. New transmission, new engine, new steering system, ready to do transfer case.... Cranking system gave out.
Occasionally it will start but has gotten to point where almost every time Bendix goes out and won't crank. Worse now it blows 40 A ignition fuse.
I have a newer Bosch starter, tested at parts store and passes all checks.
Ignition will engage the Bendix gear.
Splines all good on gear & ring gear of pressure plate.
All connections to starter are solid and low impedance (static test).
Grounds are good on truck (static test).
No shorts to ground either.
New battery, tested and good (actually tested two separate batteries)
I'm wondering if my starter cable (battery positive to starter solenoid) is worn out? The ignition / relay seems fine since it clicks.
I don't see many tutorials on this so wonder if it's a common problem at all? I have 255,000 miles on the cable.
I do see people redoing the ground from battery to engine.
Also anybody tried these thermal breakers? It's a PITA when that $5 **** fuse blows
40A Thermal breaker
40A Thermal breaker
