Modded
That Guy
- Joined
- May 3, 2009
- Posts
- 6,942
- Reaction score
- 108
I will upload the TSB for the issue on Monday night when I get back in town. And yes I am positive the issue can be fixed.
Couple more "random" questions...
1. With the front 2" down, is there any danger of hitting the sheet metal of the wheel well? Or, will the tires want to go up inside the wheel well (if the suspension can even flex that much)? I'm on factory 22"s, with no plans to go larger.
2. Does the lift gate seem too low (open) with the truck lowered, or do you simply get used to it quickly? I seem to remember thinking I was going to take an eye out when I dropped just the rear. Maybe the spindle drop lowers the front enough for just the right amount of rake to keep the tailgate up at a useable height when open....
You shouldn't have any trouble with 2".
With my truck aired out I can still walk under it (I guess unless you are like 7' tall).
Thanks! And, another thing (see?!): Does turning radius decrease at all with spindles? And/or should there be any rubbing of the well liners with just the factory 22"s?
