Cooling System Not Pressurizing
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
You should be able to find it if you pressurize the system. Grab a harbor freight coolant system tester. With a leak like that I can't imagine system not to be dropping pressure
95escahoe
Or rent one from Autozone when u bring it back you get the money back there's are pretty decent
afpj
did you look at the water pump weep hole?
Buddy who did the swap checked it out today. Said one of the factory hose clamps on a heater core hose coming off the water pump didn't look like it was good, so he replaced it. We pressurized the system and it held for a few minutes. So.... I let it idle for awhile, hoses we're soft, took it for a nice ride, system still didn't pressurize. Doesn't overheat, doesn't run hot. I don't get it. Heat works great too. He's gonna change the thermostat this weekend.
Changed out the thermostat with another one, and still having the same problem. Now instead of being between 160 and 210, now it's running at 210. Not overheating, but running warmer then it was.
rockola1971
Indiana (formerly IL)
Thats right where my 03 Tahoe 5.3L runs once it warms up and thermostat opens up and settles.
fresh350
Did you happen to check or replace the cap? It's the only thing left if you pressurized the system and it was holding with no leaks
The seal looks good on it and I don't see any cracks, but still a good idea. I'm gonna price it out. Thx
Capeles
