Designing a Custom Bluetooth Upgrade
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Back to working on this. I'm working to startup a custom fab engineering business. May have landed first customer. However, I have to get back up to speed. Been spending last week reviving this bluetooth project and studying my old skillset.
My breadboarded project can do stereo audio sink from a bluetooth source (e.g. phone). Haven't figured out bidirectional / full duplex for taking phone calls yet. I think maybe somewhat limited in that.
Bidirectional uses Hands Free Protocol, HFP. I found a library and I think the chip I have supports it. However, the audio is a bit lower quality. I think this is currently how head units handle music streaming all be it a touch degraded quality.
Found a VERY well written Advanced Audio Distribution Profile, A2DP. This is CD quality audio over bluetooth. Got up and running with it pretty quickly. Trying to figure out how to code the control buttons so you can use the head unit to play, pause, next track, etc when audio sourced from phone. Only caveat is, this protocol doesn't support headsets as in HFP for full duplex audio you'd need for taking calls. I think I can stream microphone data over A2DP protocol to phone BUT phone won't detect / use it for phone calls.
Fall back maybe a jumper where person can select using device as a HFP / headset OR A2DP but not both.
I think I can get up and running with a circuit board for A2DP pretty quickly. My cost is probably going to be around $1000 materials & fab plus time to prototype. Kind of thinking about holding out till I can add USB connection for data and charging (like old iPod car hookup for music), and a microSD slot for loading music to play. Then you could play downloaded stuff on an SD, USB Thumb, Phone via physical connection OR bluetooth along with fast charging port. That would take a bit more time which I may or may not have.
Of course the concept is for this to seamlessly plugin inline with the factory head unit harness, for what I'd coin seamless integration. Would provide those of us who like a factory look & head unit with more modern aftermarket functionality.
S33k3r
Dallas, Texas
Hopefully I'm not breaking any rules by suggesting a different forum to support your endeavor... But I suggest you check out xdadevelopers forums for this kind of stuff. There is an immense body of knowledge there, and some helpful people.
Good luck, in any case!
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Anybody who knows detailed pinouts for radio harness on GMT800 series head unit please share...
I need to start figuring out where to tie into the harness so I can get the following signals:
Remote control line ~ I assume there's a signal wire for remote control of CD changer option if there was one?
Microphone for OnStar. I'll try to tap into that line for audio input to phone / headset.
As well as... Left Aux Input, Right Aux Input, Power Line, Ground (can find these easily enough but any help is appreciated!)
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Was able to snag a factory head unit off eBay. Now I need the harness coming off backside of the head unit so I can hook-up on my bench. Then I can probe / figure out how the signals work to control external deck tape / CD changer. I'll utilitze those signals to control the BT audio source.
Saving my notes here... Also found a link with some stuff below:
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I finally got some time and wired up this circuit. It's working like a champ. My next step is to decode Class 2 Serial data with the microcontroller. I'll have to listen to when play controls are pressed so I can send command play commands to the BT source.
Anybody know where the Class 2 Serial has been decoded or I can find a breakdown of all the data on the line?
Also anybody know how the CD changer wires up to the head unit?
I'll need to use those lines to feed the audio signal into the head unit and out to the amp.
I found this but requires a login to view the attachments:
I started writing code to decode J-1850 but got sidetracked. The ELM327 chips will do it but I'd prefer to do it by myself so I don't have to add an expensive extra chip to design.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I was able to decode the data yesterday lol Now to rig up a head unit, CD changer, and or tape deck so I can intercept the communications and make the head unit think the Bluetooth module is a AUX device.
S33k3r
Dallas, Texas
Do you have a head unit with which you can work? Also, have you taken a look at any of the wiring harness options for aftermarket radios? I'm thinking they might could be helpful.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I bought a head unit from the junkyard to tinker with / right up and test out. So I have on my development bench a:
P59 PCM (Gen III SBC controller)
Delco Electronics Radio Head Unit
and the tape deck
I'm working on the circuit right now to sniff the J1850 VPW (single wire network) and decode traffic on it. I have the microcontroller rigged up. Somebody wrote a really crude program and put on GetHub. It's enough to know the data can be decoded but I need to expand on it to get everything I need. I'll probably need to make it bidirectional as well. Right now the circuit (and code) I rigged up only reads.
I found a page with description of the J1850 Signal.
psmith2449
