I am thinking about having my differential gears changed from 3.08 to 3.42 in my 2013 Yukon 4wd. First question will the gear change make a big difference for towing our 6000 lb boat? Right now the Yukon is very slow on hills and highway speeds while towing. Second question, has anyone done this before? If so what gears did you use? I was looking at Yukon gears, but a local shop that I talked to said they are not very good and tend to make gear noise. They recommended installing OEM gears in the rear and a aftermarket gear in the front. Any help or feedback would be much appreciated.
