If it was me, I’d start with a tune from BlackBear to improve power and shifting to see if that works. Tune out AFM at the same time. Plus it makes it way more fun to drive all the times you’re not towing the boat.
Not to hijack but i was wondering if 4.10 gears fit in a stock 3.42 case for my 4x4
Just wanted to give an update to everyone. I did end up changing the gears from the 3.08 to 3.42. I am only 500 miles into the new gears, so I have not had a chance to tow with them yet. Overall the truck drives a lot better. It accelerates a little quicker, but the biggest difference is that it does not down shift as much. With the 3.08 gears driving at 70-75 it keep dropping to 5th gear every time I went up a small hill. Now with the 3.42 gears it will stay in 6th. Overall I am happy with the upgrade.
Good to hear. Mine only unlocks the converter on only the steepest of grades/overpasses which you'll soon experience as well. It never downshifts to 5th save for when towing.
Do you know what brand of ring and pinion gears the shop used; assuming you farmed it out and didn't do it yourself.
I had a local guy do the work for me , but I bout the parts. The ring & pinnion was AAM.
