Do you guys have a way to delete 15+ magnetic ride
TheEngineer
Central, FL
anyone use Blisten front shocks with stock springs from the MRC setup?
We are working on something, still quite a bit away from completing full testing.
Bilstein 5100 (PN 24-251976) on 2015 Tahoe LTZ
It will require a different top mount, but hoping to reuse the lower spring mount, isolator, bumpstop and spring.
We will keep you updated.
Dearmosd
I just looked up the parts and you are correct that the non-MRC top mount is different than MRC setup.
I was looking into parts just to part together a complete assembly for easier/quicker install but again the spring part # has like 7 different part #s that I dont know the difference from each other.
I think someone mentioned not only they vary on spring rate that the non-MRC spring is much different than MRC spring as in the MRC spring was softer which makes me more curious what a aftermarket strut and softer spring from a MRC setup feel like
olyelr
Elk Rapids, MI
Hmmm. I just installed fox 2.0 coilovers on my wifes denali. They are not made for the magnaride suspension, according to fox. But, they mounted right up with no problem.
Dearmosd
what did you do with the sensor connection? Any faults on the dash?
olyelr
Elk Rapids, MI
I used the xineering magnaride delete kit. Works flawlessly.
But, as far as the upper mount goes, it bolted right on. Was the exact same setup as the oem strut, as far as bolt pattern goes.
olyelr
Elk Rapids, MI
@olyelr part number please. Are these for lifted or stock height?
Here is a link to a thread I started about them. Picture of the part numbers are in there somewhere.
https://www.tahoeyukonforum.com/threads/fox-coilovers-with-xineering-magnaride-delete-kit.114301/
They are supposedly adjustable from 0-2”, coming pre set at 2”. BUT, this is for a pickup truck, and the initial gain on my wife's yukon denali was closer to 3”.
SuitedSevens
