Door sag
alpinecrick
Western Slope of Colorado
Went through a high pressure car wash last week and washed my passenger seat. Look into it and my doors are sagging bad. So i replaced the pins and bushings... no difference.
I can feel to play when i wiggle my door up and down.
What is happeneing to me?
If the door is still sagging after replacing the pins and bushings the door pin holes in the hinges are probably wallowed out and are elongated.
Two fixes: The holes can be welded and redrilled. Need to redrill the holes in the precisely centered spot or the door wont close/fit properly.
Or replace the hinges. The factory hinges are welded to the door frame so the welds have to be ground off and the new hinges are installed with bolts and those bolt holes have to be drilled into the A pillar and into the door.
go the to a real hardware store and look for a sleeve or have some made by a machine shop, there is a few on ebay but you may have to message them for specs
Squirrelsmith
Squirrelsmith
The bushings for the pointed end of the pin are just overaized ones that are crushed a little to be ovalized. Pretty cheesy
the 18th letter
Northern New Jersey
View attachment 220354 View attachment 220352
Don't go too long without replacing them or you may end up with the hinges wallowed out also......:)
I'm gonna guess they are since the bolt that catches the door lock is showing wear and I've shaved about an 1/16 occasion metal off the top corner of the rear driver's door smh.
alpinecrick
I'm liking that idea. It would be a whole lot easier than the other options.
Come to think of it, somewhere on ebay I saw oversized bushings. Possibly allowing a guy to just drill out the pin holes a little larger and inserting the oversized bushings.
Squirrelsmith
Squirrelsmith
ok there was water dripping on the floor as i was driving it's time to get serious
kjetilaf
