06XLDenali
- Joined
- Sep 29, 2021
- Posts
- 23
- Reaction score
- 21
So I kept pushing this project back as I new it was going to be a PITA. I had 2 bolts with missing heads on the passenger side rear head. The first one closer to the front I started with a small drill bit that was pretty center. Long story short I got that one with an ez out. The one furthest to the rear I wasn't able to drill centered and screwed up right off the bat. Than tried to weld with no luck, couldn't get good ***********..I think the welder was the issue. So anyways I pulled the manifold put a new felpro gasket and new bolts. Other than the one. I ended up drilling into a jacket in the head but thank god there is no fluid pressure! Anyone know what this is? I may try a bolt on clamp device I saw online. As I'm not taking the head off and it fixed the ticking noise. Sorry for rambling
1. What is the cavity I drilled into?
2. Has anyone used this clamp with sucess?
