Yes, the latch was replaced when I replaced I lock actuator. After extensive diagnosis I think it may be related to the master window switch. When I disconnected the blue harness from the switch, puddle lights turned off but door lights stayed on. When the larger harness with the securing latch was disconnected, door panel lights turned off. The cheap Amazon replacement I ordered confirmed the switch fit, but it did not specify if it was for fixed or adjustable gas pedal. It worked for a couple of days without issues until I adjusted the gas pedal...that is when I noticed the lights would not turn off. I just ordered a new window that is designed specifically for keyless entry, with adjustable gas pedal. I will update if it fixes the problem once it's installed
