DRL problem 99 Yukon
619NJ
I just picked up a sweet 99 Yukon. The DRL indicator lights up in the cluster, but the DRLs are inoperative. I don't know where to start.
619 the Chef choppin' lips and deep-frying Mud Ducks in the Yellin' Yukon and I'm gone...
SunlitComet
OBS Jedi-Do Good
unknown at this time.
drl/fog fuse #15 located on the in-cab fuse panel. also check to see that the drl indicator goes out when the headlight switch is turned fully on.
619NJ
619NJ
I'll check the fuse tomorrow! The indicator does go out when the headlights are on.
619NJ
619NJ
Module is still there. Fuse is good. Maybe module is bad?
larfx
Both of ours are off, I don't miss it.
My first thought was the fuse missing, however there is more to the story, so I don't know, hmmm... Maybe the fuse is actually blown??
619NJ
619NJ
Fuse is good. I guess I'm gonna pull it since it doesn't work anyway
619NJ
619NJ
if the indicators light functions and fuse is good then suspect the relay next.
Thanks! When I get some time ill poke around with it, but for now, I'll just leave it be. Got my tune up parts coming on Tuesday so I guess I'll be busy on Wednesday!
tcaphou
