Dropped Denali, can't get rid of dash alarms
JFry
i dropped my wife's 08 Denali. Installed Belltech struts, spindles, rear coils and shocks. Total about 4/4".
It had autoride and the rear shocks and compressor went out.
Had no alarms until I put the new shocks in. I've installed the 3.9 25 watt resistors like mentioned in the sticky, but the message won't go away.
I removed the resistors, checked the resistance and they were all good still.
Wired them back in, disconnected the battery and tried again but same thing.
I get service stabilitrac and service traction control.
Anyone else have problems with this?
ive tried height sensors unplugged, compressor fuse pulled, but same thing.
When I pulled the resistor I checked and had 8 volts at the shock/resistor wire.
Any ideas where to go from here?
Thanks.
JFry
JFry
Also, is there anyone out there that can just reprogram the computer and tell it that it doesn't have this option?
I tried to get GM to do it, but they couldn't be bothered to put any effort into it.
kbuskill
NE. FL.
There is a plug on top of the frame rail on both sides in the rear near the upper shock mount that has a tendency to come unplugged when messing around in that area... I would check there first and make sure everything is plugged in.
I assume you put resistors on all 4 corners.
This guy may be able to reprogram it out if it is controlled by the BCM but I am not sure...
http://www.whiteautoandmedia.com/in...n=com_virtuemart&Itemid=54&vmcchk=1&Itemid=54.
JFry
JFry
Thanks, I will check to make sure that's still connected.
I did install the resistors on all four corners.
I sent them an email on that site to see if they can do that or not, thanks for the link.
ivin74
05 NBS Nali
Htown, Texas
Remove the fuse to the autoride disconnect the battery for 30 min and the autoride message will be gone for ever
JFry
JFry
I pulled the only fuse I could think it would be "SEO/ALC" auto load control?, I also have the compressor one pulled. Left cables off, touching for 1/2 hour but same thing still.
ivin74
05 NBS Nali
Htown, Texas
Let me look at set up tomorrow and I'll get back to you.
TLTFAB
I got a service stabilitrac and service traction control. Found that the abs was unplugged some how.
67RS427
Thanks.
Did you ever get this fixed? Same issue here, removed all air ride, installed resistors and have DIC message. No lights though. What was the fix?
JFry
JFry
Replaced my green amazon resistors with the gold ones. Seems to have fixed it. Didn't need to unhook batteries or pull fuses.
nicbop03
