Dual Alternators - Can?
_Dylan_
STAY FROSTY
Are my stockers 105A? Heck...does it list on the alternator? I haven't even checked...
Yes, but not at 600 rpm.
I would try to rig an idle control to get the full 105 amps at around 2000rpm.
gpracer1
Phoenix
My 140 puts out about 105 at idle but I have a very small pulley so my fans will work at idle.
After seeing those brackets I ordered a plasma cutter on amazon. :)
juggernaut26201
if you want a bigger alternator go to www.mechman.com 370 amp alternator $749 does 200 amps at 500 rpm. i have one but i need someone to answer the question of where i can buy a prefab dual alternator bracket. because i have a 1998 tahoe and am going to need 2 370 amp alternator's and 5 more batteries for a custom sound system
qukon 95
i bought a slab of steel $50.00 then made a pattern on it found a
auto welding shop to get it cut he did a good job even on the curves
in the pattern.$25.00. i did the spacers so the alt lines up with the other one. i can't the pics from my computer
but i got them in my www.photobucket.com/qlcp.
brolic
