Dustin Jackson
- Joined
- Aug 9, 2018
- Posts
- 1,525
- Reaction score
- 1,711
I finally got around to removing the broken sway bar bracket bolts thanks to some broken bolt extractors from Amazon.
Finally have the sway bar on after having it off for 2 years.
I am really impressed with these Sway bar end links from Ac Delco, the entire set of hardware is like grade 8 and the bushings seem really stout and say made in USA. The last time i ran the sway bar i used a "premium" set of end links from Moog and they had these marshmallow bushings and they were trashed after 6 months.
I tightened them just enough to where the thread started coming out the top of the end link nut.
Here is the part number of the sway bar end links
Since my last update I have discovered a problem on the driver side, there is a click in the wheel when moving it in the 12 and 6 positions. After much inspection I determined it was the wheel bearing and warrantied the timken unit and still had the problem. I thought it was the upper control arm so I warrantied that as well but the problem is still present.
I don't understand, I have replaced everything except for the tie rods and I am still having a strange click coming from the hub area when trying to wiggle the wheel. I removed the caliper and tested and the problem persists.
Leaking, once the seals start to leak, it's time to rebuild or replace. The bushings that insulate it from the chassis usually go first and are now replaceable too.@swathdiver How do you know it's time to replace the steering rack itself? I haven't tested the tie rod ends yet but I'm at 200k miles so I am thinking of replacing the steering rack as well.
