Dutchman's Tahoe Build
Dantheman1540
Sugar Loaf Mountain
UPDATE
I got my LEDs installed on the inside. They make a HUGE difference, especially since there weren't any lights on the inside when I got it. :(
I didn't realize just how dark the rear tint was until I tried to see my new LED lights through them...
This is with the flash on, because the pic without the flash was completely black. I like it!:cool:
All I have left are the puddle lights and the license tag lights.
Also the door lights. I'm going to paint the insides of those black like I saw on here somewhere. They also painted to dome lights, which I might take them back down and do as well.
I also got my fog lights replaced. They're OE style replacements with bulbs for now, but they'll be holding LEDs before long.
Take a close look. The smoked lenses look really good, but my headlight is crooked! I also noticed that my bumper sags on the passenger side.
So, I should have guessed it, one project completed, two more projects added to the list.
OH, I had an idea about the fog lights.... What if I removed the hook and cut out the divider piece between that and the OE fog and put an LED bar behind the whole opening? One thing I noticed is, it would shoot slightly towards the outsides because of the bend, but I might be able to mount it straight. Any thoughts?
Personally, I would not do that to the fogs because like you said they will point sideways and look kinda silly. But I don't know of anyone that's come up with a super clean led fog conversion for those lower valences so you should be it! :D
Dutchman
Dutchman
Charlotte, NC
I've started planning the LED conversion. The more I think about it, the more I like the idea. Now I just have to come up with a way to make that idea a reality.
One thing that I don't want is to use a flood/spot combo light bar because I think that might spread the light out too much for fog lights. Then again, this might turn out to be another set of auxiliary lights rather than true fogs, in which case the spot/flood combo will be fine.
It's still very much a work in progress, so all opinions and advice are welcome.
Dutchman
Dutchman
Charlotte, NC
UPDATE
I got some stuff from FedEx this week, so I was going to do some upgrades. But, alas, the universe had different plans for me. Out of nowhere, I got the dreaded Reduced Engine Power message and had to limp home at a blistering top speed of 40MPH (down hill, with the wind at my back).
I got out my scanner and plugged it in ...... NOTHING.:mad: Dead as a doornail (what the heck is a doornail anyway?) So I figure my scanner bit the dust and I go to get me another one. Nothing fancy, only $70. I plug it in ..... STILL NOTHING.:mad::mad: That's when I get back on my favorite forum and start doing some more research. I found out which fuse provides power to the OBD plug and swap it out. Low and behold, now both my scanners work!:beer: Time to return the new one to the store. :cool:
Now that I've gotten over that hurdle, I read the codes. It's P0120, which is the throttle position sensor. I thought it was interesting that the connected app on my phone suggested that I replace the whole throttle body assembly. Definitely sponsored by a parts store.
Anyway, I digress. I reset the code and voila!! everything works just fine. I'm guessing this is a symptom of bad grounds? So, this weekend, I'm doing the BIG3. I'll post some pics, since everybody like pics and I want to document the process for posterity.
Other things on the close horizon (that is, I've got all or most of the parts for): torsion keys for the front, Z71 springs for the rear with new longer shocks all round. New headlights and LEDs should be here in a week or so.
OH, a little update on my fog light LED conversion plans.... I've ordered a grill guard, and since it mounts where the tow hooks are, and may change the overall width of the hole, I'm going to hold off on that step until I can determine how much room I have. Then I'll find an LED light bar to fit and figure out how to mount it.
UPDATE
There's a big ground on the ds framerail, under the running board. Clean that one up. That one gets bad. Is the ground strap from the firewall to the hood still there? There's also a ground on the ps--either on the block or the head. I used to get that Reduced Engine Power alot. It was so bad I used to just leave my scanner plugged in as I was driving. It would happen and I'd reset it on the fly. Didn't even pull over. Majority of the time the plug that plugs into the tb is the culprit. Over time the wires would break internally causing your issue. They sell a replacement plug pretty cheap on Amazon. I replaced mine and I haven't had an issue since.
Yep I was just gonna mention that plug.
Dutchman
Dutchman
Charlotte, NC
I did notice that the strap to the hook is broken. I didn't think much of it, because, well, what's on the hood that needs to be grounded?
I saw the plug on Amazon and may go ahead and order it.
Thanks for the info ..... again.
That's what we're here for brotha!
I’m pretty sure all that hood ground strap is for is the hood light if you have one.
Shadfrmdabull
