Electric Fans, Worth it?
bottomline2000
Dallas, TX
Got a lot of time spent on my efan setup. I actually have an aftermarket set of Dorman fans for a '12 or '13 escalade from rock auto. I also have a factory set from an 05 yukon in a box in my garage that I pulled because I thought something was wrong with them. Turns out I just had a crappy lagging high output alternator that didn't make any power at idle. I haven't had that problem with my 270a dc power alternator but did have a problem keeping 40a relays in my Nelson harness. I finally rewired the harness to accept 70a-80a relays with the bigger blades and haven't had a problem since. I paid $250 for the factory fans from a yard, but I don't think they are any better than the $140 fans from Rock Auto. The ones from rock auto actually have more blades and seems a little quieter than the factory ones. My truck is weird and after two $600 alternators, 2 aftermarket harnesses, 2 sets of fans and finally rewiring a harness I have more invested in efans than anyone on this board because I hated that clutch fan and refused to give up on the efans lol.
You have an 03 which has better fan control than our older models. I would do a factory harness if you can find it with new dorman fans from Rock auto rather than used factory fans from a yard..Nelson makes a nice harness but i needed bigger relays to mae it work..your truck will work better in every way from heating up in the winter and cooling down in the summer without worry of burning down you truck because the clutch fan can't keep up. Power loss seemed to be higher with the clutch engaged and I just don't like the way they sound and worrying about them cooling in 100 Deg TX heat.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Turbo Riv61636
For all those who have done this swap, I recently completed mine and have noticed something odd about when the high fan 2 kicks in. Recently, in the mornings (50-60*), I put the defroster on and eventually switch to heat and notice that the high fan 2 will cycle on for about 5 seconds and then off and it repeats this process about every ten seconds. This is before the engine reaches operating temp and continues to do so once to temp. I verified the I tied into the correct a/c switch wire, per the LS1fans install instructions, so im baffled as to why this would be happening. Otherwise, this has been a great improvement.
bottomline2000
Dallas, TX
Your defroster engages your ac compressor. The fan turns on to cool the condensor not because of engine temp. You will find the fans cycle with the clutch engagement of the compressor. It's normal.
Turbo Riv61636
That's what I thought at first too, but it does the same thing once I move the switch to regular heat.
So I figured it out, if the recirc or a/c button is on, the a/c compressor will cycle on and off. Guess that makes sense.
Once you installed the fans did you have to get it tuned to turn the fans on? I bought a set of fans, now I have to get the harness from LS1 FANS also. Could you post up some pics of the install. Was it a direct fit once you pulled the clutch fan out? How hard was it to get the old fan out? Tia.
dhulsey779
Phila
When I did mine it was a direct bolt up. I purchased my harness from Nelson Performance, and it was super easy to install and was $89 for the kit.
BB performance sent me a tuned ECM in which it already had the fans programmed.
Nice! I can't wait to do mine. Nelson Performance still sell them?
www.LS1fans.com has them for about the same price and I feel they're better quality but either is probably fine. They (LS1fans.com) also sell overdrive pulleys for your alternator which is a good idea since you'll see your voltage drop when the fans kick on. The pulley upgrade adds output to your stock alternator.
22BlackDenali
