Matahoe
What kind of coolant are you using and is it pre mix? I run Dexcool mixed with distilled water and my truck starts warming up within a block of leaving my house, but I do have efans..I do not put tap water in my cooling system because of the corrosion it causes.
Sent from my SAMSUNG-SM-T377A using Tapatalk
Same here. I use distilled water with Dexcool 50/50 as stated in the service manual. I put two quarts into an empty Dex jug and then add two quarts distilled. Shake it up for about 15 secs and use. I make it a habit to always mix my coolant right away 50/50 if I remove the cap and seal on the Dexcool jug. That way I always know that if it is opened ...it has already been mixed.
