Just Fishing
Can't fix stupid
We have had some cooler weather, it is not doing it nearly as frequently. Specifically when it’s cold – cold for Florida under 60° – it will do it every few days.
I put the factory tune back on the ECM and the TCM end still getting the error. It comes up and says “engine power is reduced “and then disappears. No codes. However I’m getting a ton of fault codes. Nothing that illuminates the malfunction indicator lamp
Only real experience i have with this is when i was playing around with different tunes on my 6.0 swap.
One of the fields i copied was for the throttle body.
it gave me a clear "permeant error" for the ECM
Turned out to be an issue with the throttle body that i have installed not being compatible with the settings from another ecm/throttle body.
Apparently i could have bricked my ECM doing it... I got lucky!
Where I'm going with this, weird shit can happen with a failing part.
Sounds like the only thing you haven't changed out would be the ECM itself.
Junkyard near you?
Talk to blackbear about what it would take to swap the vin into a replacement ecm?
