Chooko
There is one more thing that bears mentioning, and I am putting it in its own post so that it stands out...
I purchased a TCI flexplate 399757. It is marked "this side must be toward engine". I installed it the other day as marked, but thought it didn't look quite right. Today I installed the starter and the gear on the starter was engaged with the flex plate teeth even when the starter gear was fully retracted. Again I looked over the flex plate and felt that it just didn't seem right. I could see that if I flipped it around the spacing with the starter gear would be better, and in addition the pads where the torque converter will mount looked wrong. I called TCI support and as soon as I gave the guy the part number and said that I had it installed as marked but that I thought it looked backwards, he cut in and said that they had a batch go out with the "this side must be toward engine" marking on the WRONG side of the flex plates. Of course I flipped it around, and now all is well. However, I think this would have been nearly catastrophic had I not caught the mistake. I guess I might have figured it out when I tried to get the transmssion and torque converter installed but by then I'd have probably had to pull the transmission back out, etc, and I would not have been happy. Hopefully this will turn up in the search function if anyone else runs across this issue in the future.
