Extra battery or Replace Battery (need help)
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
sometimes... there are 0 -> 4 ga adapters.
however generally they are too big to fit one next to the other, so you'd need to keep a 4 ga ground (not a real problem since ground is probably only 12-18 inches.)
you might try upgrading the alternator to battery to 4ga first... can't hurt, and it would sure cost less.
if your plans involve adding another amp, then a 1/0 gauge kit is a good investment.
ROBERTOcritser
ROBERTOcritser
Kentucky
I actually got a piece of 8ga wire to add on top of the wire for the alternator to battery... would that be ok or should I just go straight to 4ga?
about the 1/0 kit, thats all I needed to hear... I might buy one this week.
fatnlowtahoe504
New Orleans, LA / Hattiesburg, MS
yea thos 1000.1s pull alot of juice, i had one at first with just the factory battery it dimmed like a mother, but i added a yellow top and capacitor and it solved the problem, now im running a kicker 1500.1 and it doesnt make it dim nearly as much as the JL
ROBERTOcritser
ROBERTOcritser
Kentucky
I just checked my sub with a meter and from what I can tell, Im fairly certain its at 1.5 ohms. the meter I was using wasnt a big yellow one like most people have and isnt extremely precise but it only flickered between 1 and 2 ohms so I would guess its at 1.5
Eagle
EL PASO, TX
I figured it was a DVC 3 ohm parallel.
Add that 8 ga. to the alternator & see how it goes. 8ga + OEM wiring should be more than ample.
ROBERTOcritser
ROBERTOcritser
Kentucky
the JL site says its Nominal Impedance is 3 ohm. Here is a chart copied from there site.
Free Air Resonance (Fs): 27.2 Hz
Electrical “Q” (Qes): 0.514
Mechanical “Q” (Qms): 7.807
Total Speaker “Q” (Qts): 0.482
Equivalent Compliance (Vas): 2.33 cu. ft. / 66.0 liters
One-Way, Linear Excursion (Xmax)*: 1.15 in. / 29 mm
Reference Efficiency (no): 0.249%
Efficiency (1W/1m)**: 86.2 dB SPL
Effective Piston Area (Sd): 84 sq. in. / 0.0542 sq. m.
DC Resistance (Re): 2.47 ohm
Nominal Impedance (Znom): 3 ohm
Thermal Power Handling (Pt): 1000W
Driver Displacement: 0.14 cu. ft. / 4.0 liters
Net Weight: 45 lbs. / 20.4 kg
ROBERTOcritser
ROBERTOcritser
Kentucky
ok. well I just put that 8awg wire between my alt. and battery and Ive noticed pretty good difference in how much less voltage drop Im getting.Right now I have
1.extra 8awg between alt and battery (small red box)
2.a 4awg wire ran from my battery ground to a random body ground nearby
3.and my amp's 4awg wired straight to the red box
number 2 might sound a little off but Im pretty sure it helped even if only a lil bit.
with all of this, Ive noticed a not huge but a very good difference compared to how it was before any of that extra wiring. Definitely dont feel like I need a big battery like the one they wanted to sell me. but Im not sure what to do yet b/c I still gotta put the other amp in there with my high's and see how much that draws from everything.
Eagle
EL PASO, TX
luckily, 'highs' jsut dont require the same brute amount of power.
xwright07
