Factory look aftermarket stereo, anyone have experience?
neutube
:lol2: I was just wondering if if is a problem with the stock Bose or if it is present in RCA portion.
I'll have to check a few things out but I'm guessing power is touching a rca jack or something wire related- I'm rusty on car audio haven't installed a real system in years , being lazy I just turn it up and I don't hear it...
playing this album in its entirety also helps
yates ™
yates ™
Resident Apple hater
Iowa
I am just wondering if it is an issue with wired portion of the speaker outputs that would not be present with the RCA, may be just a dream...
BTW, don't go chasing waterfalls.
neutube
that could be, a guy on this other site added an amp and has no low vol buzz
after reading this:http://www.gm-trucks.com/forums/topic/140090-questions-about-adding-an-amp-and-speakers-to-advent-ogm1-radio/
..I have alternator wine to address
and I'm sticking to the rivers and the lakes
yates ™
yates ™
Iowa
Is it factory grounded?
I know your going to have it your way or nothing at all but I think your moving too fast.
Ponchonutty
New Washington, Ohio
The buzz with the OGM1 is something luckily I have never had an issue with. You would need to check to see if its coming through the RCAs or what? You could also try to run an extra chassis ground too. Other than that, you'd have to try some ground loop isolators?
yates ™
yates ™
Iowa
I think he is running through stock wiring so adding another ground is his only option. If we become a dealer I will run an ogm1 and if not I will probably run an aftermarket, sigh.
gibbygsxr
Kingston, NY
You can use the factory sat. antenna for aftermarket units. The plug is directly behind the glovebox. They make an adapter thats about $10 just so you know.
yates ™
yates ™
Iowa
Link please. So you have to use an aftermarket tuner but can use factory antenna??
