Fixing the Famous *CLUNK* Noise
YukonCrazy
YukonCrazy
Raleigh, NC
The new slip yoke and u-joint arrived from Fort Wayne Clutch. Picking up the new tail shaft this afternoon. Question. What is the procedure to attach the u-joint to the yoke and driveshaft?
992dr
Eastern N.C.
The caps should slide off. You may feel some pressure, its more than likely the grease inside has caused a suction.
After the caps are removed, slide one end up into one hole of the yoke and the other should fall right into place.
You'll need a press to install the caps, some people use a large C-clamp or vise or they beat them in with bfh. And finally, put the lock rings in place.
Make sure there's plenty of grease inside the caps when you re-install them.
YukonCrazy
YukonCrazy
Raleigh, NC
Any particular kind of grease?
992dr
Eastern N.C.
Bearing grease should be fine.
Is there a zerk fitting on the u-joint?
992dr
Eastern N.C.
No zerk fitting.
OK, when you pop those caps off, put a little grease inside before putting the caps back on. They usually come with some grease in them but, a little more wont hurt anything.
Are the u-joints the heavy duty ones?
YukonCrazy
YukonCrazy
Raleigh, NC
Not sure. It was included with the slip yoke from Fort Wayne Clutch. Pictured below. Should I replace the u-joint on the backend of the dirveshaft as well?
Here is a link to the u-joint they sent me.
http://www.fortwayneclutch.com/inde...niversal-joint-made-by-aam-pn-s-12479126.html
992dr
Eastern N.C.
You can, its up to you. Check its condition and make that your deciding factor. I did both of mine at the same time only because I took my driveshaft off and brought it to a shop to do the work.
Thanks for the link, I appreciate it.
YukonCrazy
YukonCrazy
Raleigh, NC
So when I take off the trans tail housing, a lot of transmission fluid is going to come out?
Fossil Fool
