Fixing the Famous *CLUNK* Noise
992dr
Eastern N.C.
If you park on level ground, yes.
I parked like this, with my front end lower than the rear. No trans fluid came out.
YukonCrazy
YukonCrazy
Raleigh, NC
I had napa machine shop press out and press in the u-joints from driveshaft and new slip yoke. I bought 2 new u-joints from napa because I wanted ones with zerk fittings. I removed the old trans extension piece and installed the new one. Greased the yoke splines and installed the driveshaft. Took it for a ride and no noise over speed bumps and no **clunk** when stopping and taking off.
royskiies
do truck have 2 slip yoke? sorry a newbie want fix this problem myself
992dr
Eastern N.C.
Thank you sir, the nickel plated yokes are the new part that came in to replace old? Are those need to bee grease as well
Any time, glad I could help.
Not sure about the nickel plated ones replacing the old. I got mine from GM, not sure if its nickel or not.
No grease, put some trans fluid on the shaft before inserting it.
Amy1960
