Here's hoping this helps:
Mine are eagle eye, if yours are the same my suggestion would be to contact them and see if you can get the two resistors ... they come with a little harness that should plug right in.
Otherwise I have no idea what all the wires do.
But there are basically two wires on each side of the plug ...
From resistor to plug: 1 black, 1 green
From plug to main harness: 1 black, 1 green and yellow
---------- Post added at 09:53 PM ---------- Previous post was at 09:48 PM ----------
Btw, if you get a metal resistor I wouldn't tape to the fixture like I did with the one that comes with it. It looks like the stock one is insulated, a metal one would melt your housings. Best place for it is on the metal frame right below where the tails go behind the bumper assy.
