Gas mileage dropping faster than the stock market, less than 200 to the tank...
YanaCakes
YanaCakes
bad cat's will cause a mpg loss also, just something to consider as well. check the temps front & rear and maybe do a backpressure test. easy enough and you can then rule it out. when mine first went bad I had a solid 2mpg loss before a code finally showed up just as I was questioning/testing the cat's because nothing else made sense, everything was solid.
You know, I was thinking about the cats the other day but thought the light would be on. I will check.
YanaCakes
YanaCakes
Check for dragging brakes also.
I replaced the pads, rotors and hubs two year ago because I was getting drag. And rechecked everything a few months ago, greased pins, etc. But… my brakes squeak, they sounded the same before I changed everything. I’m attributing it to crap brakes. Once NYC winter is over and the salt is gone, I’m gonna do ceramics and see.
YanaCakes
YanaCakes
I will double down on the catalytic converters being plugged. If so and you continue, about the time the spark plugs start to get fouled you'll notice a drop in power. When this happened to me some years ago, this last symptom hit fast. Driving home from 30 miles away, suddenly I was having to hold the pedal to the floor just to do 40 mph. By the time I got home it wouldn't do 20 miles per hour. Definitely test it before it gets that bad, made a hell of a mess of the inside of my engine. Not to mention O2 sensors. At least back then you could buy a "catalytic converter test pipe" that bolted right in for $29.... Somehow I got left in place for another hundred thousand miles :)
Oh no! I want to try to avoid that and I’m sorry that happened to you. And there is a gas smell when I start it. I think someone else mentioned that too. I will look into it.
YanaCakes
YanaCakes
You need to get a live data scanner attached and see what the fuel trims are. If you do mostly city driving, your mileage will suck. When did the lift and bigger tires get put on and how soon after that did the mpg go down? What gear are you running?
Thank you for your service
GMT800 SUV/Trucks
What is stock gears? An inexpensive decent live data scanner would be a Foxwell NT301. Check it out. You also might try a slower burning higher octane fuel, like 89. Also does a better job of cleaning deposits. Might even try some Techron additive. Over the long haul, the cleaner the better and more efficient. If you are lifted and have bigger tires and have a higher gear like 3.42 or higher, you are geared to high, especially with just city driving.
Here's a somewhat detailed video on diagnosing a clogged cat. The last half deals with the analysis of how Wes arrived at the decision to check the backpressure, along with his sketches of how things work -- or should.
YanaCakes
YanaCakes
This one?! And I have 3.42 ratio.
YanaCakes
YanaCakes
Wow, thank you so much for sharing the video. It was super helpful. I am going to try this when I get a decent scanner.
OffBrandCornDog
