Gasket replacement hell...help!
Skizzot
Skizzot
Usa
I cranked the engine with fuel pump disabled and only got the normal start up sounds. I recorded the audio but do not see a method of attaching audio to this reply. I'll have to look when I can get on my computer. But fortunately no foreign object sounds. Curious.
M3PO
Mid West/Cow Town USA
That's good! There is a good chance you don't have mechanical interference (internal engine damage).
Now back to checking all connections.
Good luck and have a Merry Christmas. I know a downed vehicle sucks, but don't let it distract you from what is most important.
Rivieraracing
That's excellent news, now it's just a matter of finding what's not hooked up right!
Skizzot
Skizzot
Usa
Any ideas on what it could be? I will have to do some research on ohms specs for each sensor to determine if something is wrong with the IAC, MAP, etc. I don't think a voltage test on the throttle bottle is possible when the engine is inoperable. Any specific hose issues that would cause significant timing issues and knocks before stalling? Everything was reconnected but I'm thinking something isn't sending a reading or has a connector issue even when seated properly. Thanks for the help!
bkboatnsleds
McHenry, IL
Are you sure all the injectors are connected? There are a LOT of little connections / vac lines that are easy to overlook - i'd double check everything.. Maybe a Vac line is off?
NC_John
North Carolina
Sounds like it could be a timing issue- recheck all your wiring, coils, plug wires, etc. I'm not sure how much you took apart (I don't recall taking any of that apart when I did my intake) but that could be it- a misfire making the racket.
M3PO
If you know someone that knows vehicles, have them take a look, we all miss things, and a new set of unbiased eyes can spot a problem.
Skizzot
Skizzot
Usa
Engine swap or rebuild? It sounded fine when cranking the engine with the fuel pump disconnected.......until the engine seized this morning. It seems like it would be cheaper to do a swap than have a repair done. I've got 186k on this engine.
jplinville
Damn...Swap is cheaper. sorry to hear about the problems. However...I'm curious what caused it.
Swap it and tear down the old one to see what caused it!
Jongrreat
