Get a catch can before any mods.
MudnRox
Rebel without a clue
Olathe, Ks
Just spent 20 minutes installing my catch can I got from Catchcans.com.
stoltz23
Into the top , down through the filter system and out through the side to the throttle body/intake .
Russell K Breeden
RKB Engineering
www.CatchCans.com
407-321-5133
14SWTahoe
Tampa FL
NORCAL SS, do you remember the thread size on the alternator bracket where you mounted your catch can? Looks like a good spot to put it.
stoltz23
If I remember correctly there is just a hole there and no threads. You will have to tap it yourself. I can't remember what size I ended up using.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
its tapped already i used a gm 10mm bolt
stoltz23
Maybe I didn't have an M10 bolt and ended up drilling and tapping it larger then. That has to be it because I know I tapped mine.
14SWTahoe
Tampa FL
Much appreciated, mine should be coming in by this weekend and just want to have everything I need to get the job done in 2 minutes! :)
Ejwr
