Getting message?:"Tighten Gas Cap" or are you Unable to fill your tank? ! Look here !
Munsk
I replaced the Canister today. Cleared the codes. Check eng light is out.
So far, So Good.
Thanks TYF!!!
Munsk.
I couldn't find the solenoid.
fire730
Louisiana
I doubt the canister was actually the problem. If the problem still exists it will take a few ignition cycles for it to show the code again.
The solenoid is back in front of the spare. The new one looks nothing like the old one. The old one was a box and the new one is round.
Munsk
When I got in and test drove it this morn, I hadn't gone 1/4 mile and I got the msg "Tighten Gas Cap" (which I had never gotten before. I drove to the gas station and topped off, about a 1/4 tank, then back home. No msgs.
Then we put about 225 miles on it. Start and stopped multiple times, No msgs yet. I haven't filled the tank again yet, I'm down to about 1/2 right now.
I'm taking it on a trip Memorial Day weekend, about 500 miles.
I guess we will see.
As far as the Solenoid goes, all I saw was a BIG box (size of a shoe box), but it didn't really look like a solenoid. It was above the axle between the Tank and the Spare tire.
Hmmm.
Munsk
So, my Check Engine Light came back on after about 250 more miles.
I know one of you guys said it would.
So I crawled under there today and took a pic.
This is what I have under there. You can see the Canister, which I already replaced, in the upper left. This GIANT box is almost directly over the rear diff. It has multiple lines going into it, with the fuel line connections, but it does not have any electrical wires going to it.
Sooo, wtf?????
Munsk.
Munsk
This is the Solenoid that I bought. Supposed to go to an 06 Yukon XL Denali.
Munsk
I found the Solenoid that I showed earlier. Its on the Intake.
I was looking near the tank... I was WAY off! I am also wondering if this is going to solve my problem. I'm guessing not.
To date, I have replaced:
The Evap Purge Solenoid
The Evap Canister,
The Fuel Cap.
Time will tell.
Munsk.
vargas8184
Munsk,
I'm new to the forum did those 3 things you replace to work for you
---------- Post added at 01:33 PM ---------- Previous post was at 01:29 PM ----------
The Evap Canister,
The Fuel Cap.
Time will tell.
Munsk.
I'm new to the forum did those 3 things you replaced work for you
Ja1034
