Good 'ol Knock Sensors
MonstroniuM
In the process of doing mine was doing rearch on the dorman and found this. Thanks for the post!
The gunk in my ports is worse. Glad I ran onto the catch can recommendation. Couldnt believe it when i had oil drip out of my intake manifold...
Kozaktrillgod
Very cool how that worked out! I have a question, I have a 06’ Z71 that has a rough idle and after a while of highway driving, throws the P0332 code. I have a slight misfire on cylinder 7 at idle, goes away under acceleration. Can the knock sensors cause this? I also have high long term fuel trim levels. Thank you.
OR VietVet
Multnomah Falls
Military
Willamette Valley
Welcome to the forum from Oregon.
Hopefully a mod will move this to it's own thread. You will get better response to your question.
Anything is possible but you need to address the P0332 code and follow the diagnostic steps. Any other codes?
Kozaktrillgod
No other codes. Just P0332 after a while of driving, I don’t believe I have reduced engine power.
blanchard7684
