Got my 2010 PPV
1BADI5
1BADI5
DMV
Project name "Undercover Sleeper"
Completed (as of 07 APR 2020)
- Texas Speed Long tube headers - 1 3/4
- Texas Speed 3" catless Y Pipe
- Magnaflow muffler 12259
- Rear resonator delete
- Ported LS7 Throttle body (ported by Me)
- Ported OEM intake manifold w/intake manifold gaskets & injector O-Rings
- AiRaid MIT intake tube / AEM dry filter
- Airbox mod (opened up inner fender and matched the Airbox)
- Cleaned the MAF
- HPTuners - work in progress
- Denso IR plugs / Taylor 10.4mm plug wires
- Gates HD Green belt, ac belt, idler pulley, auto tensioner
- Atomic Fab Performance solid motor mounts
- Holley powder coated valve covers (Tall) / new braided hoses & inline PCV
- UDR Catch can (black with black braided lines)
- AC Delco Professional 48 series Battery (3/20)
- Royal Purple HMX oil change (70k/75k)
- Royal Purple 75w90 Diff service
- Replace both Trans cooler lines (AC Delco)
- StopTech SS lines (front/Rear)
- DOT3 Flush
- AC Delco PPV front rotors
- EBC YellowStuff front pads
- Rear pads
- XTRONs HU with backup camera & forward facing camera & GPS
- OEM Remote Start added - RPO AP8, GM part 19154445
- OEM Auto Dimming rear view mirror
- OEM DIC install
- OEM Tow/Haul shifter
- OEM Steering wheel Stereo controls
- Grant Leather wrapped OEM wheel w/ fresh OEM spoke covers
- Husky mats - front/back/cargo
- New headlight housings w/ LED HI & Lows
- OEM foglights added - OEM switch/lights and wired
- LED light bar, LED tag bulbs, LED brake lights, LED Dome lights (red)
- BellTech 2/3 drop (spindles/springs)
- Spohn adjustable Panhard bar
- AC Delco Professional front sway bar end links
- Goodyear Eagle Ultra Grip GW-3 - 265/60R17) - AMAZING in the rain
- Airhorn install 150+DB
- Dropped the spare tire out, deleted the spare hoist/holder, removed OEM bottle jack and tool kit, removed the spare battery tray, removed about 5 lbs of spare antenna cable from the rear of the truck, removed excess brackets and cabling from under dash
Next up - Ready to install
* Tru Cooler MAX - 40k Trans Cooler / with custom brackets (ON HAND)
* B&M Deep Trans pan - extra 2qts with drain/temp sensor ports (ON HAND)
* 60k trans service (fluid/filter) (ON HAND)
* Aerotech gauge with column pod (ON HAND)
* OEM PPV shocks/struts & all hardware (ON HAND)
* ATI Harmonic Balancer (ON HAND)
* OEM mirrors with signals/puddle lights - shipped
1BADI5
1BADI5
DMV
Sorry, I had to update my list...…..this is how I've been tracking what I have done to the truck for future reference.
STANKHOE
Maryland
What I have done, so far (as of 11 MAR 2020)
- Hypertech Max 2.0 - tuned for E85/AFM off/trans tune
- Cleaned the MAF
- DOT3 Flush
- Rear pads
- OEM DIC install
* Texas Speed Long tube headers - 1 3/4 (ON HAND)
* Texas Speed 3" catless Y Pipe (ON HAND)
2 questions for you
Is the OEM auto dimming mirror plug & play?
Which husky mats did you get and how are they with staying in place on the vinyl floor?
Sent from my SM-G973U using Tapatalk
1BADI5
1BADI5
DMV
2 questions for you
The auto dimming mirror was plug and play
The Huskys move around alittle bit...……..but I will solve that in the spring when I switch it over to carpet (NOTE: I will keep the cargo area vinyl
Brice25
