Growing up doesn't have to suck
randeez
south florida
Aren't Eibachs hollow? Do you know the diameter and, if hollow, the tube thickness? There's SO much inconsistent info spread around the internet and when I do find specs, they're for GMT800 or '400.
dont know...front bar prob weighs 40lbs+ so i doubt it. rear bar i havent touched since i put it on, dont remember how heavy it was
pwtr02ss
Tennessee
All that girth and no grip pic. I'm....saddened.
Nice looking bars tho, for realz. I may decide to go the route when I finally get around to lowering the ol pig. Thanks for the in-depth analysis as always. Hopefully your research will save me a few bucks. We all know I could use it.
There were only two sets left on Amazon when I ordered these, so now one at $557.10. Stiffer bars are even more needed at a higher height so there's no reason to wait. You'll only need to replace the end links when you lower it. Since you're filthy rich and will be getting them, anyway, you might as well just get 'em now while they're available. You won't even feel that $600.
Here: https://a.co/d/6qKnBbQ
Here's the links you'll need to add to your drop parts. You'll need two of these: https://a.co/d/bTuWgnu
pwtr02ss
Tennessee
Sadly, I've splurged on gear to give you better views. I'm going to be recovering from that for a bit. My second (camera) body/lens isn't here yet...you'll be thankful.
I did buy the endlinks though. Thank you for that.
Also, Christmas IS just around the corner. I'm a size 35/33mm. Red is fine:)
Blackk
