Growing up doesn't have to suck
KidWgn
Certified Kid Hauler
St. Louis, MO
Hi, you must be new here! :p
So, GM deleted the cabin air filter for the GMT900. It might have been optional in the GMT800. Anyway, the slot for the filter is still there and, instead of an access door, the slot is just sealed off. You can cut out the rectangular portion sealing it off and install the filter. A retrofit kit will have a closure piece (the "access door") that is essentially identical to the factory piece. The boss for the screw to secure the closure is even still there in the HVAC housing.
Take a couple Advils and/or Ativans and slide up under the passenger floorboard. The HVAC cover is secured by three screws (7mm, IIRC). The rightmost and center are easy to remove. There's a third tucked up under the dash, in front of the center console- "good luck", you'll figure it out. Remove that cover and you'll see everything I pictured. I bought the cheapest filter retrofit kit Amazon had. No complaints at all with what I received. I don't see any functional difference in this $13 kit versus the $40 Dorman kit. Cutting out the door is a hassle. But the real chore is cleaning the crud out of the fins of the evaporator without shoving it deeper into the fins. You can only access on side of it and you're working through a ~1" x 8" slot, in the footwell up near the firewall. Ideally, you can find something the same height as the floorboard (bucket, ice chest, etc.) to place next to the door sill, sit on it and lean backwards into the floorboard to work. I've been tempted to remove the passenger seat. But I gotta suffer the hard way first.
I guess I just added that to my weekend projects list.
KidWgn
St. Louis, MO
Hey, now! That ain't bad at all. Like the hoof marks, the camera made the carbon look heavier than it was. I'd like to look in there in a year or so to see if the E85 I've been running the majority of the time is keeping it cleaner.
It wont.
Also, be sure that you're not making a bunch of short trips on E85. I just lost a $15k engine due to fuel dilution in the oil. Amsoil Dominator series 10-30 with 1200 miles on it.
Fless
Super Moderator
Elev 5,280
It wont.
I'm not sure I'd blame that on the E85; more likely the short trips without the O2 sensors getting the fuel under control.
I hope you have a really sucky vacuum cleaner. My filter install is on hold until I acquire some attachments and materials to make an attachment. The spare crevice tool I was gonna modify is too short. You gotta be able to reach about 10" up in there. I haven't been even half that deep in anything since before I was born.
Oh well. Even still, when I opened it at 200K, ~54K of that being mine, the carbon wasn't all that bad, IMO. You could still see the "+" on the pistons.
No short trips here! I live where people dump bodies to the wildlife. It's a 20-mile drive to any decent township, 12+ of which consists of 70+ MPH. I get it plenty heated. Also, I have my oil analyzed at every oil change and they've never badmouthed me.
Is that what happened to your Subie? I saw a YT video recently about E85 and short trips and the damage it causes. IIRC, the engine being torn down was from a Subaru.
I'd lean this way. A friend was all excited telling me she starts her new job on Thursday and how it's only two minutes away from her new home. I'll let her get settled in before I break the news to her.
KidWgn
St. Louis, MO
This is not the case, the trips weren't THAT short. Gasoline starts to boil around 90-degrees F, but it doesn't fully boil until 390F. Ethanol doesn't begin to boil until 140F, but it's FULLY boiling by 175F. Because gasoline starts boiling much sooner, the oil doesn't have to reach as high of temps to boil off the excess fuel by way of vapor. Ethanol boils off completely once the oil temps have risen, but it doesn't start boiling until much later.
I hope you have a really sucky vacuum cleaner. Mine filter install is on hold until I acquire some attachments and materials to make an attachment. The spare crevice tool I was gonna modify is too short. You gotta be able to reach about 10" up in there. I haven't been even half that deep in anything since before I was born.
I got plenty of suck. If not, i've been looking for an excuse to buy the Milwaukee attachment kit for my M18 shop vac.
That is indeed what happened to ole Fiona. Only got to put ~3500 miles on the built engine. What I learned in the process is that low temp thermostats aren't always a good thing. That engine never ran over 187F water temps, even after WOT blasts down the highway through 3 gears. I've discussed the oil findings in depth with several people whose lives revolve around oil knowledge; the conclusion is that it was indeed from short trips.
Yikes, that poor engine. It's NEVER going to boil off the fuel or condensation build-up. I'd tell her to invest in an electric scooter.
Funny you say that. When she told me her good news, I typed out "You should get a scooter" and was prepared to explain. Then, I realized the lesser-assholish thing to do would be to at least congratulate her first. So I backspaced it and did the right thing. I'll do the other right thing at a more appropriate time. Her car will be fine for the time she's getting settled in at her new job over the next week. She's a TikTok influencer with a cooking channel (channel- is that what they're called?) and we're supposed to have a cooking date as part of her housewarming. It'll be an opportune time to educate her.
KidWgn
St. Louis, MO
Almost forgot! Blackstone doesn't analyze fuel dilution.
Try this place, they DO test for fuel dilution. www.https://www.oaitesting.com/
Editing for clarity: they DO show fuel dilution values, but it's based on flash point, not gas spectrometry. Flash point can be wildly inaccurate.
Jasrancore
